My eris is on the way to my house and I should get it in a few days. Im going to root it. I got this phone for work to replace my blackberry that sucks and dont have a camera. Worst case I will remove the camera or drill it out.
Before I would do that though I was wondering if I could actually remove a system app such as the camera and video camera. What would be best is if there was a way to disable the driver for the camera so it wouldnt even work with other apps like bar code scanner ect. The reason I want to do it this way is because it would be reversible in the future if I wanted to sale the phone, but wouldnt be something they would consider reversible at work.
Basically if I give the phone to safety/security and they cant get it to take a picture in 10 mins or so it will pass the test.
So,
does anyone have any insite on what would need done? Would it be like removing a system app? would the kernel or radio need altered? If I decided which rom I wanted to use could someone (or even the dev that made the rom) remove the camera?
I really dont want it to work for any apps like goggles or any of the aftermarket camera apps on the market because if security decided to download a camera app on the market and try it out I would be dened.
I really dont want to do anything that isnt correctable.
So,
