Root Accidently deleted Metroweb...:(
JM033
the first thing I did when I got my new LG connect is root and remove the bloatware. me being my stupid self, accidently removed the metroweb. And whenever I go to the market and regularly navigate through the phone, I get the 'process.media' error,which i associated with the fact that I deleted metroweb. The thing is I had no backup, and after I restored to factory defaults. I still have root access. I tried installing the browser.apk and browser.obek in system/app but no success :( I don't know what to do, that error makes the phone unusable. Any suggestions?
The browser apk and odex files should have fixed it but if not you can just flash one of the stock roms in the sticky thread. Or just flash a custom rom. The stock rom thread have step by step instructions.
Here put this in system/ app browser. Apkuse android commander to push it to phone
Permissions don't work at all, still the error and still no metroweb. :/ Earlier I installed CWM and a stock rom, but can't get passed step 5, which means I can't boot into CWM. Its holding the power and volume down button right? I tried rebooting into cwmrecovery with the app but nothing. As you can tell I'm new to this stuff.. sorryy
@mrpnt I installed that but it gives me a new error when browsing the android market "the application Browser (process com.android.browser) has stopped unexpectedly
Strange. There seems to be more going on than just the browser. It shouldn't stop you from booting into recovery. Where and how did you install cwm? You could probably try the lg update tool. There's a thread in here somewhere by dulai that shows youbhow to unbrick your phone.
From this I'm installing cwm and a stock rom from here:
http://androidforums.com/connect-4g...ons-each-stock-apps-stripper-application.html
I don't think the phone is actually bricked, I mean, I can use it.
I'm on step 11. --on the website^^
I can't find the 'backup/recovery' menu.
I downloaded the rooted MS840ZVA and have it on my sd card..ready to go but I'm stuck on step 11, no such thing as that. I just don't want to brick my phone.
Those are backup roms they won't install cwm to your phone. You need to install cwm first in order to flash those backup roms.
To do that run the all in one script found here and choose install cwm.
http://androidforums.com/connect-4g...-lg-connect-4g-all-one-root-clockworkmod.html
Ok, I've installed CWM recovery and booted into recovery mode. I wiped the Dhalv cache and data, and restored the factory defaults as it said. But when I choose the 'update .zip from sd card' (which has the backup rom for my phone that I want to be restored to)
It say's "installation aborted, E:no such file or directory" It's on my sd card and It sees it why can't it work? I installed the backup rom in the clockwordmod folder inside backup just like it said...?
When you go into recovery you want to go to advanced/ backup/restore, then pick the backup file you want to restore .....not update from SD...
Don't choose update from sd card. Choose restore. Make sure the rom you downloaded is in the backup folder of you clockworkmod folder.
I went to restore and I did exactly what you said but got an MD5 mismatch error. Any ideas? Should I re download it?
Many kudos to you my man. That seemed to solve my issue. Still kinda weird how i tried reinstalling the metrobrowser and it didnt work. Well youre a lifesaver, thanks to all who posted! :)
