Hi guys,
Thank you for the one click root--worked great on the first try!
I purchased this phone with the hopes of using the Hotspot feature. I tried several apps in the market to enable it, but the result is just a dialog box that says "Hotspot is not supported". Also, I have noticed the Mobile Data automatically turns off if you have WiFi enabled.
I had assumed that rooting my phone would help, but now I'm realizing that was probably just the first step. Would I need to download a particular custom ROM in order to add the Hotspot functionality?
Thank you!
Dave
Thank you!
Dave
Everything worked out great thanks interdepth!!!!
*** Please post as much information as possible in as concise and clear a manner as possible for maximum helpability
