blaze420916
Android Expert
Does this com in a zip so I can flash through cwm?
dont sweat it, next version is being worked on. i gave mystery some hosting off my site so no more waiting no more slow downloads all super fast connections
Did you read the op?
Could have just said yes or no its as simple as that but instead you decided to write a few sentences about looking back through over 200 posts for the one answer to that question. Be a community,we help each other but thanks I'll scroll through all posts looking for my answer.
Is there a zip file that I can use in cwm that will put me back to stock. Phone says most apps in market can not used on my phone and I know they can. Need to start over. Please help
look for my post a few pages back, i attached the file in it..people..please read thru the threads before asking the same questions over and over again
would probably be better off if the file was attached in the op as well
I'm trying to revert back to the stock rom, any way to do this?
were can i find this packagelook in the odin return to stock...
This doesn't appear to be a full rom btw.
Its a file swap, changing small things like ui app and build.prop and such. So you are essentially on a themed stock rom
also there is a flash package around here to revert to stock ui without getting the snitch (yellow triangle that reveals you are on a custom rom or have flashed your phone)
