Is there any way I can change it to make it faster and make it stop crashing? Cus this thing sucks. If so how can I do it?
I have my phone rooted and I tried deleting many apps but it still crashes a lot. Btw I'm running 2.2
I'm not running any at all and I only have a few shortcuts on my desktop.
Thanks for replying and yea I hate this phone I should of gotten the LG from metro. This phone is super slow it lags too much. Also I have tried what you've told me but its still slow. I honestly do not understand why people can like this phone. I mean yea it has a track ball but other than that it just sucks. Also I don't understand how a company could put out such a crappy phone. I like the fact that the android is an open mobile os unlike ios (even though I preffer ios) I don't have to jailbreak it to tweak it up a bit. Anyway thanks again for replying. I appreciate it.
Not when you put Gingerbread on it and over clock it.![]()
I'm not tech savy so how would I do that? Also what does overclock mean? And what's to brick a phone mean? I'm guessing gingerbread is 2.3?
Start here:I still wanna try it out
Well, overclocking can make the cpu run hotter, which in theory can shorten its life span, but unless you're planning on keeping this phone for a few years or something I wouldn't really worry about it too much.Will "overclocking" it make it die faster?
Ohh no I might buy the LG in a couple of monthsWell, overclocking can make the cpu run hotter, which in theory can shorten its life span, but unless you're planning on keeping this phone for a few years or something I wouldn't really worry about it too much.
So what speed would you recommend?It can if you overclock (speed up your processors faster than their factory settings) too high and start overheating your hardware.
Use launcherpro, it's free and a lot better then the default
So each phone is different?
"Not all Ascends are created equal." It's a cheap phone, and the manufacturers used different parts on different phones. But it's still a decent phone, and if you consider the monetary costs, its a great phone.
Damn I should of done research before buying this phone. But ima still try to overclock it and try to remove some bloatware. Then I'm going to get the LG once I get s job again. Cus I'm 17 at the moment.
Just remember a couple things...
There are generally 2 types of Ascends. Regular, and lazy ones. Lazies won't overclock over 700 MHz. They crash.
When you get going and try to overclock, DO NOT check the "Set on boot" box until you have tried it out for a while. If you set it too high and the phone just shuts down, you'll be lucky if you don't have to re-flash your phone to get it to work again since it will just crash when you boot.
Dont forget there is another ascend called POS Ascend that want overclock past 600 mhz...![]()
