Okay, I am NOT computer savvy by any means...I think my question pertains to what you are all talking about in here so I thought I would give this a try.
I have a HTC Desire, just upgraded to the Android 2.2 and am having low memory problems on my phone. The main issue is that 99% of the apps are not listed as being transferable to the SD card. I found a youtube video that showed a way to "trick" the phone to allowing more apps to be transfered to the SD card, but when I get to the command prompt portion I get this error: "adb is not recognized internal or external command,operable program or batch file". Looking at the Android SDK that I downloaded, it shows the adb has been moved. The "help" part says to do the following: The adb tool has moved to platform-tools/
If you don't see this directory in your SDK,
launch the SDK and AVD Manager (execute the android tool)
and install "Android SDK Platform-tools"
Please also update your PATH environment variable to
include the platform-tools/ directory, so you can
execute adb from any location.
But I don't know what it means by updating a path environment. Any help would be much appreciated!
