Help add widget
justonly
i have a problem adding widget to my home screen.
i downloaded a widget from a market, however i couldnt locate my widget when i long press on my home screen and click on widget.
any ideas how to go about?
it is an apps called 3G auto onOff. i was instructed by the application that to add the widget on homescreen.
but i couldnt find it after i installed this app
You could instal App Remover free from the market, instal, open and see if 3G auto onOff is actually there.
the app is installed already. just that when i want to use it as widget, by holding on the homescreen, add widget. couldnt find the app widget.
I'd try a battery pull. If that fails you could always uninstall it then install it again.
