Admire battery
Fuzzy13
Extreme Android User
How is the Admire battery bigger than Esteem battery? That makes no sense?
1600mah vs 1500mah.
Goes to show how much cell phone companies care about putting more technology into battery life.
Doesnt matter, the Admire dies just as fast if not more so and doesnt even have 4G lol
It just seems strange being that 4G eats so much battery and plus the Esteem having the HDMI out.
If anything, a battery could be made to the largest Mah possible but still fit with stock battery cover. 2000mah maybe? that would make a noticeable difference I would assume. :confused:
the RAZR MAXX has a 3380Mah battery I think it is, so..... ;)
Holy shit it does? I knew it was bigger but I didn't know the specs on it. Wow. I know the Note has a 2200 or 2500 or something like that. Not sure.
I bet that thing is as big as the phone and as flat as a baseball card. lol. It has to be the size of the phone I would assume right? Unless they have dsicovered some new technology. Li-Ion to 10th power.
Dont think its much thicker than the RAZR ;)
Hey PG, is there anything that controls "vibrate intensity" within the phone? My vibrate is kinda stuttering. Like every 3rd press doesn't vibrate or along those lines.
For example. Using swype and if you want to delete a sentence and you press and hold back normally it will pulse once each words deletes and it doesnt work like every 3rd or 4th word.
Is this a digitizer issue or a settings issue I can adjust?
Framework>res>values>arrays theres a bunch of values lines for vibe ;)
