Root advice, help, opinions
corance
Not sure where this goes but I want it to go here cause this is where all the action is. So I just installed the newest cm9 and love it! Since I'm doing something new I want a new look completely. I was using fancy widget for a clock but I'm over it. What do you guys use? I want sleek and modern and something that doesn't drain battery. Also on cm7 at any given time I had roughly 130mb ram being used...on cm9 it's over 200! Is that normal? No new apps, actually I have less running.
Yeah ICS/CM9 uses more RAM than cm7 more features in the OS and such. I would search on XDA and see if you can find any themes. If you find any good ones create a post and share. Since cm9 is slowly picking up more user base for the Triumph don't think a lot of users know what to use yet. But just like cm7, cm9 has the ability for themes, we just need to find them :D
I use the Make Your Own Clock app. It's fun and the sky is the limit. I am providing a screenshot of the cheesy Halloween clock I made. You can share your creations with other users too. Here is a gallery with clocks others have made. This a small sample.
I use One More Clock.
It has like over 60 clocks and each one can be modified by turning on/off different elements as well as edited for color, within the app. I liked it so much I got the paid version.
