pootietang
Hi, I am using an LG Optimus V. I recently rooted it using the all things root guide, and I am having trouble with the ADW Launcher. First, when I have a theme set it works fine, but I start having random reboots that seem to occur only when using an application. Also, when it restarts some general specifications are there, but the theme is dropped, but if I custom set a shortcut icon to an image from the theme pack it remains the same. The problem is the action button portion of the theme is dropped so i can't just simply change all of the icons to my liking. Now, I figured okay I will get everything set the way I want, and create a back up then restore when ever needed. Well the back up is not restoring to the latest files that I created, and I noticed that the save has been going much quicker leaving me to believe that it is no longer creating a back up. Has any one had similar problems, and what solution did they come to? I looked up something on it, and I locked desktop rotation to portrait which hasn't helped. The real issue is obviously the reboots. Please help.
