rivercat123
Member
There seems to be a minor change with the way the camera works after the 2.3.3 update. Before the update when using the camera in a dimly lit room, I would focus on an object, press the shutter and then the flash would come on for 2-3 seconds and the screen would light up showing the object I was shooting. After the update everything works the same except when you press the shutter, the screen stays dark. The problem the dark screen causes is the inability to make a slight adjustment like centering the object you are shooting in the 2-3 seconds while it is focusing on the object. Has anyone else noticed this change?
