FirebirdStud
Hi Everyone.
My phone wont stop restarting. It loads up until the home screen, and after about 8 seconds it automatically reboots.
The details of where I am at:
It's a UK Vodafone phone GT-I9100. I rooted it using ironass's guide, and installed a different modem that plays better with the American technology (I've left the UK and now live in Minnesota, USA.) That modem also was used per ironass's guide.
PDA: I9100BULPD
Phone: I9100BULP7
CSC: I9100VODLP9
I used rooting file CF-Root-SGS2_XX_NEE_LPD-v5.5-CWM5.
Im using the ModemRIL_MUGLD3 model file, that has matching RIL and modem files.
Ive installed Siyah kernel, via the guide. I was on version 4.1.4, but now on 4.1.5, installed just now (details explained further down).
This all was working great for about a week. I had switched modems only twice, and settled on this one that worked great here.
I used the GS2WiperV1.91 to clean out any crud before the kernel install.
About 4 days ago the phone got angry. The charging indicator would be slow to realize it was plugged in, it would say that there was a usb cable plugged in when there wasn't one. It would also refuse to go to sleep mode, and the battery drain was horrendous (I used CPU spy to check up on it). It felt like something just wasn't allowing it to go to sleep, but I had no clue what it was.
I had a battery issue before, back in February, and determined the USB port was probably to blame after researching on this board for some time (spurious battery warning thread helped a lot). I installed a new one off eBay (bought in the UK) and the phone was good as new! It even connected to Kies now! (which it never had since new in September).
So, with these new problems, I thought the usb port went out again. Ordered a new one shipped from USA, installed it, and same reboot problem. However, the charging issues are gone, the phone recognizes the charger right away when plugged in and removed. So this was part of the problem.
Now it boots up long enough for me to go into clockworkmod and restart in recovery mode. I went in and cleared the cache partition and the devlik cache. Still reboots.
I went and wiped the kernel again with GS2WiperV1.91, and installed Siyah kernel 4.1.5. Didn't help.
So now I'm stuck with a phone that wont stop rebooting. How can I get it to stop being a bitch?
I did make a backup of my phone using clockworkmod, I saved a copy of the efs folder, and I used the free version of titanium backup to backup my apps when I first rooted this phone about 3 weeks ago. I'm worried that the free version of titanium backup wont save my game data though for some of my games. Would it have saved it?
I also have a lot of files hidden with Hide It Pro. I'm worried that if I do a factory reset I will also lose these files. The files were originally on the external SD card, but I don't know where the app "hides" the files to.
So, you can see that factory resetting should be my last available option (I really, really don't want to do that) and besides, would that even help this issue?
I look forward to assistance. I really liked my rooted phone and all of the options I had. Thanks to ironass I got the phone just about where I wanted it, and then this stupid rebooting thing popped up.
PDA: I9100BULPD
Phone: I9100BULP7
CSC: I9100VODLP9
