Root after partitioning and flashing a few roms...
esthernrob
i finally took the leap and partitioned my sd card... installed a2sd-froyo... i have flashed 3 roms since then and what is happening is amazing... (unless i'm wiping wrong - cache, dalvik, data, then zzzvr-superwipe)... all my apps show right up, no reinstall necessary... is this supposed to happen this way? if so, garsh, should've partitioned a long time ago... :D and the roms run great... (as great as they can without a custom kernel, hint, hint) always finding out something new... what a wonderful evo-world it is...
yeah i took the plunge for the kingdom rom as well and i should have done a long time ago. just so you know you should be wiping sd ext in your recovery. however, i find that flashing sense roms should be ok without wiping it, but flashing an aosp rom from sense or vice versa you should definitely wipe sd ext.
