Really? What posts are you missing?
Someone posted something and then someone else posted back - it was a bit ill mannered and hot tempered - I think with the new rules of the "zero tolerance" had the posts removed.
Either way its not that big a deal...
dustin thanks for all your efforts. i followed your original thread a while ago, but just happened to stumble upon this. great work!
i was lucky to purchase the HTC 1500 only because of the cost, but i was seriously thinking of the seido 1750 at the time.
this will definitely influence my decision on the next battery HTC 2150 vs Seido 3500
And in the end seidio has never responded after the facts.
I personally have moved to an X, and I will not purchase any products from them, and I will cite the testing here and recommend to my friends to be wary.
Again, thanks Dustin!!!
I don't think SEIDIO, in any shape or form can respond to these testing scenarios - I am fairly confident the folks in Texas are far removed from whats happening in their Asia suppliers.
I know, its easy to say, I hope people beleive me when I say it - I've been through oddities like this before. Its amazing what happens.
Dustin, thanks for your meticulous work on this. Did I read your recent post correctly that you believe their 3500 is closer to that actual value? I'm wondering about getting it from Amazon for $57 because once Froyo 2.2 comes out soon, I want to have more juice.
It is also a major PITA to keep popping off the cover to swap the two smaller 1300 & 1750 (really 1500) batteries. I know those attaching tabs are going to break before much longer, so would rather just bit the bullet and get the 3500, and cut out the back raised outline of my silicone cover I got earlier from Verizon when first got the phone in April.
In any event, I'd never give Seidio money for anything after this. Sad too. Had they merely owned up to it, apologized, and offered some form of optional recourse to those affected (I wasn't one of those people), I'd have had a ton more respect for them than I do now.
Its tough, I think they think they obviously have a test to make that battery be a 1750 mAh - considering there is rarely a real standard to go by - they can't come here and say anything except for what they've already said.
The proof remains to be in the guts of the battery - had they manufacturered it tighter and better so that it wasn't so easily dismantled - they could have hidden behind anything they wanted. But that conincidental batteries looking like other batteries thing is to much for me..
Plus one.
Interesting read here... I've got a Cadex battery analyzer that I use for two-way radio batteries. I've configured it to test an OEM 1300 mAh battery that came in my DINC.
I"ve also got a Sedio 1750 mAh battery that I got right after getting the phone. I'll post what I find if anything with more details once I'm done.
Dustin PM me your address , I will send you my 3000mah Hong Kong battery for testing (if you still want to do that)
I've been using it for about a month and am still getting on average 25-30hrs up and 12hrs awake with pretty normal usage (nav, lots of music, bluetooth, wifi, 3g , 100% brightness etc..) I think it would be good to get a good test on one of these batteries
