justtom
GOOGLE SEARCH IS YOUR FRIEND IRAM 2000MAH BATTERY
MY GEAR THIS IS WHAT I HAVE
Battery package might vary You do not need a special back cover for this battery. * Brand : AceSoft
* Voltage: 3.7V. * Battery Capacity: 2180 mAh * High quality Li-Ion battery. * Battery Type: Lithium Ion. * Keep an extra battery on hand for extend standby and talk times. * Integrated microchip prevents overcharging and lengthens battery life. * The best replacement spare battery for your phone. * Our battery is sent out with little or no power, so please charge it for about 4 - 6 hours before using. * The battery operation time depends on conditions such as: Transmitting power level, Signal (distance between the phone and the base station), Network parameters defined by the operator. * This Battery could also be charged in the phone directly thru the cell phone charger . AC/USB Desktop Battery Charger
* Charge your cell phone battery without the phone. LED charging indicator * Also work with OEM (original) battery.
* Quick charge with automatic constant current control prevents battery from over charging, short circuit, and electronic shock. * Small and compact, perfect accessory for traveling.Designed to charge battery quickly and safely. * This charger will never overcharge your battery, prolong the life and performance of the battery. * LED charging light indicator. Turn red in charging, turn blue when done. * Input: AC 100-240V 50/60Hz 150mAh. * Output: DC 4.2V 350mAh
Compatible with:
ZTE Warp , N860 ( Boost Mobile )
This battery charger comes with Battery charger and USB port can work simultaneously. Charge a battery in the slot and in the same time charge your USB device thru USB Port. an USB outlet which could also be used for various cell phones, as long as the cell phone could be charged thru an USB port.
Package Description
2180 mAh AceSoft Li_ion Battery Quantity: 2
Quantity: 1
i like it
