Help Air Command problem with S Pen for Galaxy Note 3
Hi Guys,
I have a very weird problem. Once i remove my S pen the air command launches normally, but when i start using the mobile while the pen is still out and then decide to launch the air command again by putting the S pen near the screen and pressing the button on the S pen, the air command does not launch anymore. I have to insert the pen back again in the mobile and remove it out again so that the air view can be launched.
Anyone faced the same issue ?
Any solution ?
Thanks,
Rakony
Welcome to AF and the Note 3 forum, Rakony Slicks! :)
I just tried it on my phone and mine works like you are describing you want yours to, I can get Air Command to pop up again,
I thought it might be because in Settings/ Device/ S Pen, I have pen removal option set to None. However, upon switching it to start air command and testing, it still works.
This is not something I have tried before and I was surprised that it worked, actually. I am out of ideas as to what the problem may be, too. :confused:
Maybe one of the other members will have an idea for you.
Again, though, welcome to the forums! :)
:D
Thanks Dustwun 77 for your greeting and welcoming
yeah its a strange problem, but i found out 1 thing, i tried returning back my mobile to factory settings, the problem was solved. BUT when i installed back all my apps again, the problem came back again.....:confused:
there must be something causing this issue, ,maybe one of the apps​
If you have not solved the problem I suggest that you another shot at resetting the phone to factory settings and then add the apps back one at a time, trying the S Pen stuff until it happens again. Then you will know what app if any is causing the problem.
Good Luck and when you get the problem figured out how about letting us know what the solution was.
Air Command makes it easy to access S Pen features from any app, anytime. You may need to turn Air Command on. From the Home screen, touch Menu Menu Key > Settings Settings Icon > Controls Controls Tab Icon > Air command Air Command Settings Icon and touch the slider Slider Off to turn Air Command on Slider On . To activate Air Command, hold the S Pen about a quarter-inch above the screen of your device, then press and hold the S Pen button. The Air Command controller will open over the area.
Hope the above resolves your issues. No factory settings required mate. Its just so easy :)
Hi Guys,
Any solution ?
Thanks,
Rakony
Do you have any software installed that uses the proximity sensor or gestures or do you have
PEN Window Manager installed?
Hi Guys,
Any solution ?
Thanks,
Rakony
Do you have an S View case on your phone?
For AT&T also, so probably for all N3s. Turning Air Command off turns off the pen button bringing up the menu.
Eureka!
After 2 months, finally figured out thanks to several comments above.
Was having the same problem... air command menu working fine when initially pulling pen from the silo, but not once it was out. Hovering would not open the air menu.
It wasn't any of the settings for me, they were all on just fine.
It was the SEQUENCE. What worked today finally was to
1. Hover
2. Don't touch the screen at all
3. Quickly click and RELEASE the s.pen button.
Finally. Really need this since the old screen capture method *press and hold button* no longer works.
Happy day... remember, don't touch the screen, just hover, then press and release.
