Root Alarm Clock Icon
Thank You, will try to find it... little lost here. :confused:
You are rooted right? I noticed your backup said stock zvd so I wasnt sure. IF YOUR ROOTED you can do this:
I think he means for you to pull framework-res.apk (from system/framework) and SystemUI.apk (from system/app) to your computer then open them with 7zip or the likes and go into the res>drawable-hdpi folders of each of them then look for the icon you want to get rid of and delete it from the archive. Then close it all back up and push the files back to your phone.:)
