ChangeOfJinzo
Member
I am here posting a APN/Data fix. I am back since i got a new laptop. I see work is being put into CM13 right so that is very pleasant to see! Guess i know what im gonna be working on
DISCLAIMER: I AM NOT HELD RESPONSIBLE FOR ANY DAMAGES OR BRICKS YOU MIGHT GET FROM FLASHING THIS. ALL THIS IS, IS A DATA/ALL IN ONE APN FIX. I HAVE NOT GOTTEN ANY BRICKS OR GOTTEN ANY DAMAGES FROM FLASHING THIS BUT THERE IS ALWAYS THAT SLIGHT RISK JUST SO YOU KNOW. IT IS YOUR CHOICE TO FLASH THIS NOT MINE.
READ!: THIS HAS ALL SPRINT AND MVNO COMPANY'S THAT USE SPRINT TOWERS ONLY. RingPlus, Sprint, Textnow, FreedomPop, Boost Mobile, Ting, Virgin Mobile.
DIRECRIONS: •Doanload Zip. •Go into recovery. •Flash zip. •Then a menu will pop up asking what carrier you have, choose. •Reboot back into phone. •Pleazd allow a minute before anything. •If you don't have 3G/4G go into APN settings and just select the the only APN that pops up and wait a minute. •Bam, you should at least have 3g now.
WORKS ON (Updated): Works on CM13, CM12.1, Blisspop, CandyRom (for people that still use these). Working to improve this too.
THIS HAS BROUGHT 3G AND MOSTLY 4G BACK TO ME. IM NOT SAYING IT WILL BRING 4G BACK COMPLETLY BUT IT SHOULD BRING SOME SORTS OF DATA BACK LIKE 3G. I GET SOLID 3G AND SPOTS OF 4G WHEN I USE THIS.This has been tested on CM12.1 and tested it on CM13. It should work on other roms and if so or not, please tell me so i can put it here!
Credits: Ahmad Amarullah for making AROMA Installer.
Have any problems what so ever? Send me a logcat or anything in that nature but i think there will be no problem. This SHOULD fix data problems you may have but if not, i'm sorry: ill work on it.
Wanna put this in your OP? Go ahead, just give credit. I hope this helps people!!
Download link: (Updated)(5/3/2016) V1.2 https://www.androidfilehost.com/?fid=24531035584725098
