Root All In One Data/APN Fix for LG Volt on CM13/CM12 (Other ROMs too)
Did this help your data problems?
  • Yes
  • No
  • Kinda
Results are only viewable after voting.
@che_edgar make sure you wait a minute and then select the apn from the apn selection. Make sure you also pick the right provider when you flash it.
Well I got service but no data. Not only that but I flashed the VM APN fix but got it as a TextNow APN fix.
@che_edgar thank you for telling me and good luck.
Its working properly, shows that its from VM and I can call. However, it doesn't show me an option for me to select an APN. So I don't get 3g nor 4g. Moreover, I will try this on the go today as my reception at my house is not the best. Thanks for this fix I hope you can improve it more. I appreciate it.
I believe when there's only one APN in the apn-conf.XML file it does not show a list when there's multiple APNs in the apn-conf.xml file then it give the option to change APN I have tested this Theory with multiple roms
It does show a list. I have tested this before. When i was on CM12.1, i tested this plenty of times. it still showed the APN selection menu under data settings but there is only one to choice from when you flash this.
I get an LTE signal but the actual data connection remains disconnected . Switching off / on airplane mode or wifi initiates an LTE data connection(cellular network state) but it never succeeds and will ultimately end up showing as disconnected when you look it up under settings/ About phone/ sim status . Am on CM13 beta. If only we could find a way to get a dialing code that will force a profile update in CM13 , I believe all our APN issues will be resolved.
Used the APN fix with ringplus and everything seems better. I waited a minuted then updated PRL and Profile and it worked. Getting solid LTE now instead of spotty. Thanks!
This did not work for me on CM13 but I did find Ringpplus 4.4zip that worked for me on ringplus service. All the other solutions including all-in-one-date-fix picked up LTE signals but could never connect to it when 4G was enabled . Would suggest to Op and author of this thread to compare the link posted and the all-in-one -apn fix to see the difference and incorporate it to the all-in-one
Had a problem with this at first, just got a my phone from Freedompop recently and flashed this and CM13 with only LTE working afterwards. Finally noticed under APNs that freedompop(n.f6.ispsn) "bearer" only had ehrpd and LTE while the SPRINT apn had evdo-0/ a/ b and 1xRTT. Added those 4 to the freedompop bearer and 3g started working.
Not sure if this was on purpose or just something my phone wasn't setting right, FP phones have lte+3g while their hotspots are LTE only.
