I have VM and it is not working at all I can't even get the icon to appear have tried everything multiple times but to no avail. The only 2 problems I am having with CM 13 is the LTE/3G and the green tint on the rear facing camera forward facing camera works perfectly. Anyone with VM have any ideas on what I can do to even get 3G or LTE or even the icons to show? Also there is no where to change the settings for APN on CM 13 I'm wondering if the issue may be in the CDMA its set to NV instead of RUM/SIM can't seem to get it to change. I'm a new to this stuff so not sure? Any ideas?Anyone on VM? If so is this working. My LTE is not that great with the other fix.
Tried this it did nothingHave u tried shutting wifi off going to *#*#4636#*#* phone information set to LTE/CDMA auto prl and rebooting
Tried this it did nothing![]()
Use the original VM fix. Go to the CM12.1 thread and go to the very first page. There it'll tell you about the original fix.I have VM and it is not working at all I can't even get the icon to appear have tried everything multiple times but to no avail. The only 2 problems I am having with CM 13 is the LTE/3G and the green tint on the rear facing camera forward facing camera works perfectly. Anyone with VM have any ideas on what I can do to even get 3G or LTE or even the icons to show? Also there is no where to change the settings for APN on CM 13 I'm wondering if the issue may be in the CDMA its set to NV instead of RUM/SIM can't seem to get it to change. I'm a new to this stuff so not sure? Any ideas?
So I put it to that setting and restarted after waiting about 10 mins i had 3G i think became greedy and wanted to see if i put it to lte/cdma if i could get LTE and it didnt work and now i have tried puting it back to CDMA Auto PRL and restarting i cant get 3GTry setting it to just CDMA Auto PRL that will put your phone in 3G mode see if that works
Trying to get my data to work... i saw it appear briefly but thats about it.. I tried *#*#4636#*#* settings are already at LTE/CDMA Auto PRL.. I changed to CDMA auto PRL and rebooted, when it rebooted it was changed back o LTE/CDMA
No luck for me.. Im using LG Volt with Ringplus
What carrier are you on?I couldn't get data to work with CM13 no matter what I tried. I couldn't even get the APN settings to show up.
Tried from a clean CM13 several times as well as going back to ZV6 stock and doing a PRL update. (Data works with stock or CM12.1)
Gave up and went back to CM12.1 and all is well.
You can go back to CM 13 and flash this fix on this thread currently and try what the 'best answer's says at the beginning of this thread. If it doesn't work flash and follow what this guy posted on this thread: http://androidforums.com/threads/cm12-1-unofficial-beta.905257/page-66#post-7000962. I hope I helped because cm13 is really cool with the new update Spock brought.Ah, sorry, I left that important piece of information out... Carrier is RingPlus.
This http://www.mediafire.com/?b39ptx5sgu6u9iu is the newest oneFor those who got your CM13 working, where did you get your ROM?
*deleted*
https://androidforums.com/threads/found-a-fix.1148948/#post-7550636Using old CM13 Version. Testing with this. (The only version that gives me no issue with SMS
