If you want a froyo rom ReflexTsense is very good, but if you want to try the newer Gingerbread sense 3.0 mixes i can recomend the insertcoin roms. I am using v40 of the nightly builds & that is very stable
just to check something
are you changing the freq in set cpu? some phones dont like running any higher than 1113 so if you have it at 1152 or higher then it can cause instability and boot loops
a2sd uses an ext partition on your SD card (possibly much like leddroid version you have?)
Clockworkmod is recovery.
CM7 is a hboot partition table that changes the size allocated to the rom and apps, without partitioning SD card. You need to be S-off for that.
Did you partition your SD card for leedroid?
You want the a2sd version that uses a standard hboot
Might be worth changing the radio? I know that sounds random but anything is worth giving a go. I had problems with SMS app force closing on me every now and again for past year or so. I couldnt for the life of me figure out what the problem was. I changed roms froyo/GB versions and kernels nothing worked! But once I changed the radio it stopped completely...
i take it you were getting this still with other roms and standard rom then?Well, it's gone back to HTC now. I'm not overly keen on messing about with the radio. Recovery and ROMs I can cope with - S-off and radio aren't really things I want to get my hands dirty with yet.
it did look like a typical hardware fault.
