windsorclarenc
My phone is ALWAYS roaming, no exaggeration. I was wondering if updating radios might fix this? If so could somebody help me out with a link?
Have you tried simply updating your profile/PRL?
Also, your not flashed to the Verison PRL are you?
Finally, there should be a setting in wireless and networks. Make sure you aren't set to ROAMING ONLY.
If none of those work, upgrading the radio might.
Are you with Sprint?
What ROM are you on? If its Sense-Based, Calling Sprint and telling them your issue might be helpful. Do NOT tell them your rooted.
You can update profile/prl by going to settings, system updates, profile and prl. DO NOT do the HTC software update
It's pretty much every ROM. Currently is Cyanogenmod 7.1. I went to settings and don't see system updates. I tried going into about phone->status and clicked on prl but noting happens. It's prl version 60681.
hi first what rom u using and u would want to b on a sense rom and did u flash any radios resently ..in case u did something by mistake...and yes u should update prl before profile..with a little more info im sure the brain trust here will help u on ur way to happy rooting
hi again i 2 am using cm 7 nites so yes make a nan backup of 7.1 wipe cache and delvick then 3 time viper superwipe then try going back to a sense mik 3 is a great rom and update ur prl first then profile after that then go back to recovery do a wipe of cache and delvick and 3 times viper superwipe again then install ur nan backup of 7.1 then do a caulkins temp wipe and a cache and delvick wipe and reboot...if this doent do it then maybe radio pack is needed ...radios can b found on xda evo page above the evo roms ..good luck
Good advice about making a nandroid.
Its not required to wipe the phone before restoring a nandroid though. Wiping won't hurt anything, but it'll save you some time.
