I have been lurking here a lot, but I come under the impression that everything here is for a GSM Desire. Is there a forum here for the CDMA devise?![]()
From what I understand the CDMA is a US kind of thing and most here seem to be across the big pond. Comming from the HTC Touch Pro 2, I know on that phone I should always stay away from the GSM version of anything except apps. Putting a GSM rom on a CDMA phone would cause it to be bricked, and made useless. The same went with unlocking it, there was 2 of them also. But since they don't seem to separate the two version of the Desire, I was just wondering if the same holds true?
I read the Moving all apps thread you wrote, looks pretty simple. Will try it out once I can upgrade to 2.2
And thanks. I made my guide hoping it would be pretty simple.Very useful for 2.2 users.
Actually, as far as I know (and I'm no expert) this forum covers everything. I think GSM desire information just tends to be posted more as the CDMA versionis rarer. But it shouldn't really matter anyway as the software is more or less the same. So 99% of advice given should apply to both versions. I would have thought only really really techical stuff to do with cell bands and stuff that I have no idea about would be specific, but they are never really discussed anyway. So most stuff metioned here like wallpapers, sense UI, rooting, apps, wifi etc should still apply to both![]()
