It's all personal preference. IMO, FU and RM are both excellent apps and worthwhile to keep on my phone. RM is a good way to find ROMs from multiple sources, so more often than not, I use Clockwork. I'm currently running Fresh053, so if I want to check up on new Fresh ROMs, themes, or tweaks, I go into RM first, flash Amon, then open up FU.Thanks! So is it just safer and easier to flash over Amon RA and leave it if I plan to stick with Fresh? Is there a further need for Clockwork?
IIRC, Amon RA is stricter about needing signed packages; Clockwork will flash any ol' thing. Also, Amon RA stubbornly holds to using Vol Up + Vol Down as the function for Go Back in his menus, even though this is a pain on phones such as the Evo where the volume switch is a rocker. A minor complaint, albeit a common one.
the amon-ra version im using does not require vol up + down to return, mine actually has a return option to select.
You are using an old version. Current version here:
[Recovery] [18-June-2010] RA-evo-v1.7.0.1 - xda-developers
