Hi
the receive sensitiviy will be at maximum already and the front ends used on the LG phones is pretty hot. Your transmit power is controlled by a handshaking protocol.
If you are using the phone in the same place, maybe at home, then improve the antenna on the wireless router.
very simple to do if the antenna is on a reverse SMA connector,
HTH
Richard
