theperfectpunk
If anyone has problems with fastboot or clockworkmod recovery one can use the flash_image and dump_image commands to backup and restore partitions.
These commands are currently not built in the Micromax A70 so you'll need to download the binaries attached as flash_image.zip and dump_image.zip. Also you'll need to download Android Terminal Emulator(or adb or a similar app) from the market.
Oh and one more thing your phone should be rooted for this procedure to work
1. Extract the zip files attached with this post to the sd card root.(You can probably extract it elsewhere but then the commands below should be changed accordingly)
2. Open Android Terminal Emulator(or adb or a similar app) in the phone.
3. First Of All type
in the Android Terminal Emulator(or adb or a similar app) to get superuser privileges or permissions
4. Now type the following code to dump or backup a partition.
For example the code to dump the recovery partition in sd card root is :
5. Similarly to flash or restore a partition, type the following code :
For example the code to flash the recovery partition in with a file named recovery.img located in sd card root is :
Note(s):
1. If you encounter out of memory or a similar error, just restart the phone and it'll work
2. Personally i don't recommend these commands to flash anything other than recovery and data partition, as the phone may be operating on files at that instant.
Code:
su
Code:
mount -o remount,exec /dev/block//vold/179:1 /sdcard
cd /sdcard
./dump_image <partition> <location of file to be dumped>
Code:
cd /sdcard
./dump_image recovery /sdcard/recovery.img
Code:
cd /sdcard
./flash_image <partition> <location of file to be flashed>
Code:
cd /sdcard
./flash_image recovery /sdcard/recovery.img
Note(s):
any ways i have made a better one click solutions for u guys ! just see the A75 -all things root forum
Not related to dump/flash image, I might add.
