Eris Ed
Android Expert
From Techradar, looks like the 2.2 update is coming tomorrow
Three dropping Android 2.2 update for Desire users | News | TechRadar UK
16:00 Taiwan time is 09:00 here so not long left for them.....
Of course Three have ruined it, thats why I debranded and gone to stock Froyo..
That's why it didn't work, OTA updates only work on stock ROMs. You'll need to go back to stock and then get the OTA
Anyone know the OTA file name? Wanna get it to check the radio version
If you've rooted using unrEVOked then you'll have a custom recovery which doesn't like HTC updates. What ROM did your phone come with 'out the box'? What ROM version are you on now?
The leaked 3 RUU files are:
RUU_Bravo_H3G_UK_1.20.771.3_Radio_32.36.00.28U_4.06.00.02_2
RUU_Bravo_H3G_UK_1.22.771.1_Radio_32.36.00.28U_4.06.00.02_2
I'd say get the later 1.22 one and flash this. You WILL go back to stock and lose all data but you can then hopefully get the OTA update to 2.25.771.1
Right, how did you root? You could just turn off signature checking on your custom recovery and see if that helps...would save you setting everything up again.
If not, get the 1.22 RUU file above, connect your phone with HTC Sync and run the file. It will then go through the update process
