forgottenstarx
Flashed the rom using odin... working awesome... rooted the device also..
can u tell how to get indian language support ?
Hmm.. buddy i think you need to re-flash, (and if you root, use battery calibration), because my phone is much faster than it was on VillianROM.
To your other complains, i'd say i prefer these small not-so-important bugs than improper gps and sleep of death..
Screen lag is there in any gb ROM for Ace right now, and that is the ROM's fault, no need for gpu for that
IF you chose you can switch back, but i'm staying on it.
will i be able to update from froyo to gingerbread?
i updated my galaxy ace to 2.3.4 and my screen turns off randomly like every 5 minutes and i need to press power to turn on the screen, so i downgraded my phone to 2.3.3 and the problem is still there, anyone know how to fix this? (sorry for my bad English)
ACFYeah it is possible to upgrade the ace to 2.3.4, BUT it isnt an official Samsung upgrade.hi buddy...
is this the official update by samsung??
iam planning to buy ace todaywill i be able to update from froyo to gingerbread?
pls advice
thnks
I have upgraded the firmware successfully to 2.3.4 and everything works fine except one issue. Previously when the firmware was froyo, I was able to access the android market, gmail and facebook etc.. using my data connection (2G).. After upgrading to 2.3.4, not able to access any of the applications which needs internet. I am only able to access gmail and facebook via browsers only. When I use Wi-Fi connection, I am able to access all the applications now also, but the problem is only with 2G connection.
Anyone faced similar issue after upgrading firmware..?? Any ideas/suggestions??
Hi guys,
I've been using my s5830 for four days now after flashing it from Froyo to Gingerbread 2.3.4
Do anyone experience about 1.5 sec response before the unlock screen appears?
And also, I experience setting the phone in Vibrate / Silent, but when I receive an SMS message, the message alert tone goes off and the phone is not on silent mode anymore.
Is there any fix for this? Or do I just have my setting wrong?
Note:
I rooted my phone and set an mp3 file as message alert tone
. Cannot say anything about the battery life though as its just five minutes after updating.
Yea. I am from india too and i have done it to my ace.Hii... I am frm India...will this work for me..
New Firmware is out..!
S5830XXKPH - Android 2.3.4
build day: 3.6.2011
Credits : ingbrzy@XDA
Download: http://goo.gl/MqLvU
ROOT from Android 2.3.3 is working...!
Screenshot:
http://i56.tinypic.com/28l3pw.png
Advantages of this version:
1. In the service menu items are available again GPS settings.
2. In the standard browser now work Flash. (you can see how it work if open samsung.com on your ace`s browser)
3. Restored performance of not-original headset buttons.
4. camera quality better than KPE
Update: Mediafire Mirror for the FW
Password: ekache99
Credits for MF upload: ekache@XDA
Flashing Instructions:
1) Turn off your phone
2) Remove your SIM Card and SD Card
3) Extract previously downloaded firmware
4) Open ODIN 4.38 on your PC
5) Select from extracted archive: OPS-OPS, Boot-APBOOT, Phone-MODEM, PDA-CODE, CSC-CSC (leave EFS and One Package empty)
6) Connect your phone via USB into PC
7) When the screen is turned on hold POWER+VOLUME DOWN+HOME and wait until the phone enters the Download Mode
8) If ODIN detected and recognised your phone should light up the first square to the left side
9) Press "Start" button and wait, the process should take ~5 minutes
10) If all goes well your phone should reboot automatically
11) Square should change the color to blue and display "PASS" it means that flashing process was successful and we have the newest firmware
12) Disconnect your phone
13) Turn off your phone
14) Insert your SIM Card and SD Card again
15) Turn on your phone
16) Now you have the newest firmware!
