Root Android Commander errors?
Fuzzy13
Extreme Android User
Is anyone having any errors with AC today?
Error
(" is not a valid integer)
I've tried everything but it still has an error. Someone else is having this problem as well so I figured it might be wide spread. If anyone can check and let me know that would be great.
Error
What are u tryin to do ??
If anyone can just open up AC and let me know if it shows up an error that would be great. That's all I need to know. The site is down and the forum is down and with 1 other person already having the same problem, Im thinking its a problem on their side but I want to make sure.
Just try to connect your phone and open. Youll see an error if there is one. Just let me know guys. Thanks
Will let u kno let me download it and do it I Reset my pc to Factory defualt thats why i dnt have it lol
Ok that's all i needed to know.
It just started this error. I thought it was #2 ROM so i went back down a version. That wasn't it. I haven't changed anything else. I have the newest version of AC and i even tried an older version and still had the same problem. I re installed phone drivers as well.
I don't know what it could be.
Thing is i can still operate ac but the "loading"bar is still present as if the program was still loading. Idk. Strange.
Just tried it.. Having the same exact issues as well.. If you come across a solution please share it..
well I solved it by having my usb connected and rebooting my phone, while it was booting up AC recognized it
Recognizing was never the problem for me.
I did fix it though. It was the automatic update on startup. Being that the website is down, AC is searching for an update when it starts and obviously isn't finding anything thus throwing an error. Everything works perfect now.
