Android Incredible
case0040
The story,
I downloaded a notification sound from a starfox 64 soundboard, i know cheesy.
The creator soon took the soundboard down and made it only available for the iPhone I think.
I had to reboot my phone because I may have locked myself out with the draw the line security code feature.
Since then, that sound file was moved to a Music file.
I have no USB cable, so hooking it up to my computer is not an option.
Is there anyway i can send a file from my phone to my computer?
(try googling "Android+Send Music file FROM phone")
Is there anyway from the phone i can set it as a notification sound?
I already think not because i have tried everything, looked under ever rock.. etc.
The only option it gives me is to set it as a Ringtone.
The story,
Bluetooth!
or dropbox.
I'm sorry, I have to ask. If you have no USB cable how are you charging your phone? The USB cable that plugs into the charger works as a normal USB cable too. I use it all the time to plug my phone into my computer.
You can also use a file manager app and send the file as an email attachment to yourself, then open it up on the PC.
If you want it as a notification on your phone, you can create a folder on the root of your SD card called Notifications and copy/paste said file in there. It will then come up as an available notification option when you are choosing notifications on the phone.
