Root Android Market
ghost915
Is anyone else having problems trying to download apps? I t was running great last and now it sucks. It won't download anything keeps timing out and say there is an error. I can download apps no problem with my tablet and I know I have a wifi connection and signal.
Any ideas?
Still having troulbe with CT3.3 not connecting to market to download apps. Keeps timing out or no connection. Becoming a real pain in the ass. Worked perfectly before up grading to 3.3.
is your web-browser working? Seems kinda odd that just the market would break like that.
You could try going into Applications under settings and clearing all of Play's data to see if it clears it up
Nope web browser is not working ether. I have cleared everything on it and still not working right.
Mine started to screw up Sat afternoon. Failed trying to update some apps on its own. I did some manual updates and some worked, some didn't. Eventually they all did, but I had to keep trying. I assumed it was Google since it worked fine that morning. :confused:
Browser is fine.
Everything works fine on my tablet.
I have also noticed I am not getting a good signal on the phone now ether. I use to get a really good signal in our house now I don't But even with the wi-fi on the market should work just fine like my tablet does.
Have you guys tried deleting the market and installing an older version then letting it up date ? That has fixed some of my market issues in the past .
Yep tryed that still runs like crap. I am about to turn back over to the older version. Worked fine after I installed it last night for a while now I does nothing. Along with the browser not even GoStore works. No idea why all of this stuff is not owrking.
Hmmmm , you guys got me to wondering if my market was working so I updated Angry Birds . Seems to be working fine . It just downloaded a 22mb file with no problems .
Last night i got a purchasing error in the play store (with free apps :confused: )
Nothing would download for me either... I cleared the data in manage applications, and uninstalled updates
It became the market again (briefly) and re-updated to play store again. And all is well... for now :rolleyes:
im also on CTmod 3.3, i flashed the new "Hexed' theme a couple days ago and that is when these problems started. Proly has nothing to do with anything, so I don't know...Im back to CT2.4 for tha time being
Whenever I've had issues like that a good wipe and reflash usually always fixed those type of problems... I thought it might've been due to flashing on a low battery, but that'd be just a guess..
The only permanent fix I've found for the "error processing purchase" message is to delete the app data for GoogleServicesFramework. I've tried several different things over the past few days and this is the only thing that has fixed the issue completely.
Everytihg you guys have said I have done and still have problems with the store?market not working right. I did get all of my apps again before it messed up again. Seems to be only messing up the store/market and the browser. Everything else works fine. And the signal is not as great as use to be with 2.4. Not sure why this is, it should be better going up in builds not down.
Are you on FA19?
If so, go back to EJ06, then install CTmod, etc etc
FA19 has all kinds of signal problems. You can blame Samsung for that
It's strange that only a few people are having this issue . Normally if it's a problem with the ROM , a lot of people will experience it .
It's got me curious as to what is causing this .
me too tried everything and can't purchase but can update fine
i'm updateing as we speak and was also able to buy when i got the stuff to fix gps and now just can't purchase
