Help Android messaging problem. Please help, its my first android phone
When in messaging on my HTC Desire S it says the contacts phone number beside their name, how to I change it?! its REALLY annoying me
for example...
Shirly Wirly (M 12345678910): heyyy how are you
how do i fix this, becuase this isnt the name i saved the contact in 'people' ... for this example it would have been shirly wirly
@ jamieeerobinso .....have you solved this? I also have problem with this..so annoying.. Thanks :)
I don't think that you can this is default behaviour for the Sense messaging application, perhaps installing another market place SMS application, would give you the option.
If you do install another SMS app make it GoSMS... It's the best one out there
