Root android.process.acore has stopped unexpectedly - prompt when i attempt to join contacts together
jetfactor
Member
lately, when i try and join my contacts up in my phonebook (ex. an existing contact i had with the same facebook contact) the prompt: "Sorry! The process android.process.acore has stopped unexpectedly. Please try again." pops up, offering me no choice but to force close it.
i've tried restarting my phone, reflashing the rom while restoring apps+data only (no system data restore), pulling battery. although everything else works fine, it's pretty annoying.
my phone is rooted running harmonia (aphrodite + picasticks).
anyone have any ideas on how to fix this? much thanks.
Did you do all these things before installing the custom ROM?
1.wipe cache partition.
2.wipe dalvik cache(advanced section)
3.wipe data/factory reset.Now that your rooted YOU MUST NEVER USE THE FACTORY RESET IN THE PRIVACY MENU ON THE PHONE
4.format boot,system,data,and cache
All these things must be done when coming from a stock ROM,or Installing a new ROM. These must be done to prevent any residual date from corrupting the newly installed ROM.
yup, did all of it. anyhow, i went and flashed again, and now it works properly.
I lost count as to how many different ROM's and recovery's I've flashed. Glad to see I'm not the only on with the ROM flashing bug.
LOL, yeah I got the flashing bug but my wife hates it as it takes away from her Angry Birds time.
