Android stock calendar
bradnsj
Stock Android Calendar
My Micro SD card recently packed up, but not before I backed it up to my PC.
I bought a new SD card and tried to restore apps etc to it.
Most things restored, except for a few apps that seemed to go missing, but Contacts and Calendar failed.
With the help of HTC support, I was able to restore my contacts, but they told me that the Cal;endar had not got this facility.
Does anyone know how I can restore the calendar from my PC to my phone's SD c ard, please.
URGENT
As I need to know where I should be tomorrow.
Best wishes
Neil
my 'old' calendar is the stock one pre-loaded on the HTC Desire.
I use HTC Synch to connect with MS Outlook on my PC, but haven't synched for a few weeks!
Install Google Calendar Sync to sync your outlook calendar with Google, then sync the phone with Google and both should now show the same appointments. I am assuming that you have your appointments in Outlook on the PC.
