. On a more serious note:
Are there any apps on your phone that support ads?
A few of them.
-If these apps are running they will pull data which drains your battery.
How many widgets on your main screen?
10
-This is bad. Shortcuts are good, widgets are bad with battery.
How is your reception the majority of the time?
Signal is good depending on where I am <---- MetroPCS
-The lower the signal the harder the phone works to find the signal, the faster it drains
How is your brightness set up? Screen timeout?
All the way down, screen timeout is about 1min
-Screen timeout must be set way lower, say you get a notification, the screen turns on and stays on for 1 min and you didn't even realized
Any apps that require to be running all the time? Like your app guard?
I have JuiceDefender and Deep Sleep Battery Saver on 2gether lol
-Get rid of deep sleep battery
Is your auto sync on or off?
Off
-Ok that's good
-Also if you're overclocked your battery will drain
I tweaked some things and I just saw that it has it's on CPU setter also!
Hmmm... I was at 89% when I deleted deep sleep and now I've lost 9% with barely using my phone, this is ridiculous -__- and I've clocked my phone pretty low like Max1024 min 120.
