JWhipple
I've been monitoring my phone using Watchdog Lite ( https://market.android.com/details?id=com.zomut.watchdoglite ) for the past 4 days - it's showing that what is hanging the phone up is actually the Android System, NOT some app that I have installed. It's done it at least a dozen times now. It's logging extremely high CPU usage by the Android System.
Doesn't seem to make any difference how I setup the phone (I've done it probably a dozen times now), and whether or not I am using the Esteem Optimizer app. Also, I have wiped both the internal SD as well as the external SD. The symptoms seen are LONG (2-3-4-5 second) pauses between doing things, or when launching a new app that is not already running, and then the app won't even always launch - just tends to hang at a black screen. Oh yes, I have also done soft as well as hard resets.
Starting to sound like LG should be owning the issue. I'm hopeful (but not holding my breath) that once we (*IF* WE) get CM that this problem will go away.
[EDIT]
Here's the apps I have installed other than WatchDog Lite.
Adfree Android
Adobe Flash Player 11
AudioManager Pro
Box (box.net app)
Dropbox
Equalizer
Facebook (NOTE: Was not running during any times that the phone hung - I kill it with the included LG task manager when I'm not using it)
Gmail
Google Chrome to Phone
Google Maps
Google Music
Google Voice
Google+
Keyboard from Android 2.3
LG Esteem Optimizer
Quadrant Standard
QuickPic
Rhapsody
Root Explorer
Slacker Radio
Speedtest.net
Street View on Google Maps
Superuser
Twitter
WidgetLocker (installed but not being used)
Wifi Analyzer
Wireless Tether for Root Users
YouTube
[EDIT]
Adfree Android
AudioManager Pro
Box (box.net app)
Dropbox
Equalizer
Gmail
Google Maps
Google Music
Google Voice
Google+
LG Esteem Optimizer
Quadrant Standard
QuickPic
Rhapsody
Root Explorer
Slacker Radio
Speedtest.net
Superuser
Wifi Analyzer
YouTube
