Rebooted and now says android system at 80%I think it's more a case of the battery stats getting stuck. Sometimes they report excessive usage for something which has only been used very briefly.
Try rebooting and that should reset it.
that Android was working 98% of the time.
Will keep you posted.You need to give it a few hours to get a better reading. If you are using your phone then it is normal for android system to appear at the top of the list. However if the phone is idle then you would expect to see cell standby or phone idle above it.
Android system encompasses lots of different processes which other apps may require use of. For instance if I spend time playing a game such as smiley pops that will increase the battery stats for android system, presumably because the game is using screen, sound, vibration, etc.
