egg_head
Member
Hell yes!
After a few hours trying to uncover the dialing code string for the Fascinate, I finally figured it out!
I've dug into *almost* all the AndroidManifest.xmls to compose a list of hidden menus you can gain access to.
I shouldn't have to say it, but I will..
I'm not responsible if you brick your phone.
Play with these things at your own risk.
Even if I said it's been tested by me and confirmed to work.
It's not my fault if your phone takes a crap on you.
Make a backup of your phone.
I will be doing some more testing and will uncover more hidden menus, but this is what I have for now..
Some members of another forum where having trouble using these codes and I've discovered that you need Hiddenmenu enabled. To enable Hiddenmenu, do the following:
Go into the Dialer and enter *#83786633 then press the Home key
Go back into the phone dialer and enter *#22745927
Now a box will come up asking for the SPC code. Enter 000000
Press the Hiddenmenu Enable radio button.
Now you can use these codes.
The dialing code string you have to use is *#<code>#
Here are some things you can gain access to
Audio Tuning
*#28346#
Several audio tuning menus.
I've only tested the two items below:
To silence boot and shutdown audio go to Situation/BOOTSOUND and turn the values to 0. I've tested and confirmed this works.
To silence the volume key audio when turning the volume up/down go to Situation/VOLUMEKEY and turn the values to 0. I've tested and confirmed this works.
Full Bat Popup
*#3844228#
This allows you to disable the full battery pop-up.
I have tested this and it works successfully.
HwCodec
*#0002*28346#
Audio path volume controls. Most importantly, it looks like there's a sidetone adjustment.
I have not tested any of these items yet.
Shutdown
*#7594#
This enables you to shut your phone off by long-pressing the power/lock key.
No more pop-up confirmation.
I've also discovered by doing this, it will disable the puzzle/glass unlock screen.
Personally, having to push a button and slide the screen is redundant.
I like the one-step process.
Diag/Testing Mode
*#4636*1111#
Audio Tuning
*#28346#
Full Bat Popup
*#3844228#
HwCodec
*#0002*28346#
Shutdown
*#7594#
Diag/Testing Mode
*#4636*1111#
