In order for angry birds to play fast and smooth you have to be overclocked to at least 748MHz.
That requires you to be rooted with either an overclocking kernel installed, or a custom ROM.
You need to install an overclocking kernel or a custom ROM. You need to install a custom recovery and make a backup of your current ROM in the recovery first and foremost( you can delete something vital by mistake). Click on the backup and restore section then select the backup option. After that you can proceded with the ROM or kernel install.
Let me check and see what all you going to need as I don't get a chance to help in this phone forum very often.
EDIT: I'll go ahead and move your thread to the All Things Root sub-forum.
A kernel will just tweak what you can't see. A ROM has a custom kernel, plus is heavily themed, and or, has bloatware already removed as well as having some much needed apps pre-installed.
If you like the stock look and just want to overclock, just flash a kernel.
