Help angry birds on hero?
shrub77
Hey guys. Angry birds is really fun. But it lags a lot on my hero to the point of unplayability. I heard of an angry birds lite. does anyone no when it will be released or away to run it with out the lag?
Thanks.
If you're rooted, OC your phone and remember to turn off data before playing. It makes the game quite playable that way. As for when the Lite version is coming, no idea. I think Rovio has only teased it so far and not set a release yet.
Did turning off the data work? I'm having the same issue. How exactly do you turn off the data.
Also, the app says it's only 14MB but when I download and install it, it takes up 16.6MB on my phone. I have un-installed it because of so many issues!
Turning off the data helps because it makes it so the ads no longer load. It appears that the ads are a major cause of slowdown for this game in particular. To turn off the data in a sense ROM, just use the HTC widget for mobile network.
This helped, turned on airplane mode and the game was much smoother:)
