shigglyboo
My battery life wasn't that bad before switching to CM7, some users reported extended battery life after loading the CM7 rom. However, I seem to be running out of juice a bit faster than normal, and the top two things that are using it are "Android System" @ 47% and "Dialer" at 47%. I went to sleep last night with 90% charge and woke up with 20%. The only app that was running was an alarm clock app. I didn't make or receive any phone calls, so I'm wondering why on earth the Dialer app used half my charge over night. Cell Standby reports 5% usage and Phone Idle 3%.
Are there any known settings in the CM7 settings that decrease battery life? For instance, I switched the status bar to display dBM instead of signal bars, and I turned on a balanced color scheme (cool).
I also have Juice Defender installed, and GPS & Bluetooth were off, although WiFi was on.
Right now it looks like I'll have to charge every morning, afternoon and evening, even if I don't use the phone much.
