Hey guys, when you charge your captivate, do you let it drain down to 0 first, so that the phone turns off? Or can you start charging at 1 or higher? That being asked, do you have to charge your phone while it's turned off or can I use it while it's charging? Which is the best way?
Thanks in advance =)
Btw, I have already posted this on another category, but did not get any replies...so I'm posting it here to see if anyone here might help me, ty.
. If you see your battery begin to bulge from charging you should replace both the battery and the charger. The Captivate has a built in battery management system that does this for you but should you ever choose to purchase an OEM charger make sure it is designed to charge your battery. My two cents!
