NorthernNoel
Member
Looks as though my Desire needs another return to HTC for repair
(flashlight issue) and I'm trying to restore it to stock. It's a Vodafone branded Desire so I've downloaded this RUU and run it. Shipped ROMs
On rebooting after running it I have the HTC logo with a black bar on the top/bottom. If I then press the power button it makes the HTC boot noise and the screen goes black.
If I go into the bootloader it still appears to be S-Off. I used Revolutionary to S-Off it and the H-Boot is 6.93.1002. I've done a bit of searching about and found that I may need to run a downgrade.img? Although I've struggled to find where I can get it from and if that's what I actually should be doing.
Any ideas would be much appreciated cheers
(flashlight issue) and I'm trying to restore it to stock. It's a Vodafone branded Desire so I've downloaded this RUU and run it. Shipped ROMsOn rebooting after running it I have the HTC logo with a black bar on the top/bottom. If I then press the power button it makes the HTC boot noise and the screen goes black.
