Root AnTuTu Benchmark Scores
Lizzord30
Well after seeing the Quadrant Scores and the big differences from CT2.4 and CM7 I thought maybe its something weird with that benchamark program so I want to get some scores from AnTuTu TO see some differences.
Post with what mod your running and what size/speed SD card. Then Total score or screen shot of score.
for me:
Ct2.4 stock 2g SD card(what ever speed that is lol)
and 1656 Score
for me:
and 1656 Score
Its no point to post this cause its already a thread for this.its called "Quadrant Scores"
So people should post AnTuTu scores under the Quadrant post? Seams too messy and like a thread jack so i wanted to make a new post.
Ya u should.that's y their is administrators and moderators to edit and fix threads.so that's y.but that's justmy opinion
try and have the OP of the other thread edit and include other apps and the differences. someone could post what their quadrant standard score is and another apps immediately after. try and determine if there are huge fluctuations.
It seems from Bloodawn's new thread their definetely are high fluctuations between roms...a little fluctuation between score apps. but not too significant, except maybe the last one he tried.
Anybody using this as a Benchmark?
Running CM7 Beta 5
SD Card 16GB Class 10
1 GB sd-ext.
using original Hroark sd-ext kernel.
Does anybody have an opinion if it is better or worse than Quadrant Standard?
Oh, and using laptop today, somebody please teach me how to properly attach a jpg image.
Normally use TapATalk. but got real work to do today for a change.
:DOK Wy , here ya go on those directions .
PhotoBucket from Phone :
Download PhotoBucket and create account .
To post pictures , open PhotoBucket , tap the "upload" tab , tap the "upload image" tab , choose one or multiple pictures then tap "done" . It will now begin uploading image . After image, images has uploaded , tap the "My Albums" tab , tap the picture that you want to post . After full size picture appears , tap the menu tab ON YOUR PHONE . You will then see (Share Media,, View Links, Download , etc), tap the "View Links" tab . At the bottom of the list that pops up , you will see IMG , long press on it and select "Copy All", then just open up the Phandroid app or Tapatalk and when you wanna post , long press and paste your image .
You can also copy and paste images from your computer . This is advised if you want to post multiple pictures at the same time . It's basically the same process as on your phone if not easier.
From computer :
Go to the PhotoBucket site and sign in , once you have uploaded pictures , just copy the IMG Code and paste to your post on Android Forums .
From computer :
Thanks. Biker just got around to this. It was on my list. Lol.
By the way, I used the app, but they also have a mobile web formatted website that looks good in Dolphin HD. Not sure what the app will do better, but the site might be a option.
I believe in using a good Browser instead of apps whenever possible.
