I tried Quattrimus and it worked really smooth. The only thing that was buggy was Voice Search, and he still has to work on a few things that were disabled in the options. The rom itself can essentially be used every day though.
I couldn't handle the store crashes, tapatalk crashes, and random reboot and really needed video cam the other day and ended up sticking with it.
Since ICS is relatively new, most ICS roms are still in beta testing phase. Anything in beta (or whatever testing phase it may be in) is going to have bugs. That's the nature of testing phases.
What a lot of people fail to realize is if you install a beta rom then you have to be ready to report the bugs you find. That's a part of being a beta tester.
Edit: Going to hit the report button and request your thread be moved to the All Things Root forums where people can better answer your question.
Thanks for the info all in one spot, saving me searching time. Haven't tried CAI yet, so that will be next
You mean Alpha.
Im sorry, what do you mean? :what:
I thought it was Jelly Bean?Its not all bananna splits for everyone else, they are just finally getting it running right on most tablets too. And Im sure as soon as its very stable on most items. 5.0 dixieCup will be out.
It is Jelly Bean as far as I know.Plus they can't use Dixie Cup cause that's a trademarked name.And really android 5.0 dixie cup sounds lame.I thought it was Jelly Bean?
