What I'm trying to find now is a way to screen mirror it to the Smart TV so she can stream things to tablet and then to the TV. If any of you have found a solution, I'm open to suggestion here...
I just bought the new Note 10.1 LTE version in black and has been playing with it the whole day. It's my first large size android tablet. I picked this one over the sleeker looking iPad Air. So far no major complains. The higher screen resolution makes a huge difference and finally taking written notes with the s-pen is actually practical. ( I also have a Note2 and hardly touch the pen function at all. )
Only minor quips I have found so far are :
1) The screen is a bit more yellowish compared to the iPad Air, esp whites. Might be a setting issue. Otherwise, it is as good as the iPad Air.
2) Google Music does not have the equalizer feature
3) Not enough case selection. Even Samsung haven't release theirs in our market
4) There is a slight pause of 1 to 2 sec when creating a new S-Note. With the procesing speed of this tablet, it should have been immediate.
I enjoyed reading your opinions. I do have to ask if you've actually had time to use both the iPad Air and the Note 10.1 2014 side by side long enough to make the decisions that you came up with in number 1 above? Also, are you referring to just the screen on the two tablets, or overall functionality of both? Don't get me wrong, I'm not saying that either is as good or better than the other. Thanks
Yes I do. The store I bought the Samsung Note 10.1 have both demo-units so I am able to do a side by side. Even when compared to my older iPad 3 or my Note2 which has a super-AMOLED screen, the white is just not "as white" as the iPad. I think people called that "warmer color". Certainly it is not distracting and after using it for a while I don't notice it anymore unless compared that to my other devices. Other than this very minor aspect, the display is same to me, ie both crisp and sharp.
Maybe Samsung table users just have no clue.
I guess no one really knows anything about their tablets,good or bad items. You ask a question in the Apple iPad forum, you get many answers.Maybe Samsung table users just have no clue.
Well this makes me think i will really give the new Apple IPad Air and the soon to be released new Apple iPad Mini, a real close look. As I already have two iPads a 2&4 also two Samsung tablets a Tab2 and the 10.1 note. But if i read better reports on the Apple products then the Samsung ones, it's so long Samsung.![]()
Did you try changing screen mode?
Yep, give them a closer look, read reviews and comparisons.
From early reviews it does not seem that iPad Air stands any chances against 2014 Edition Note, though.
