***SOLVED***
My son, well 5 of us, have the Admire.
But my son dropped his cell in the toilet today.
First mistake he made was to turn it on and not remove the battery.
I had a look at it and the only big issue I see so far is that the menu button keeps coming on, or the menu screen as if menu keeps being pressed.
After that I took out the battery and put it (phone) someplace warm and dry to heal.
I have heard about alcohol baths to displace the water but do not want to try this at all unless I know what I am doing.
His reset button and a small paper strip on his battery turned pink, so yes, the Admire does indeed have water submersion indicators for those trying to fool warranty claims.
Any ideas?
***SOLVED***
Covering the phone in instant rice did the trick to draw all remaining moisture from the phone. Thank you to all that helped!
Any ideas?
***SOLVED***
