if backed up to titanium you can get them.I misplaced my phone for the time being and was wondering if there was anyway to get my contacts from an sd card? Like maybe a backup? or the contacts.apk? Or any other way, lol thanks
Or cwm backup
have one but all I can see are (xml) permission files. Can u perhaps elaborate on how 2 see my contacts on the pc?I misplaced my phone for the time being and was wondering if there was anyway to get my contacts from an sd card? Like maybe a backup? or the contacts.apk? Or any other way, lol thanks
Make a unique Gmail account to store contacts/calender and synq as necessary.
It is free and works perfectly.
Your contacts sync to your google account in the cloud, but there is a function in the contacts menu to import/export the contacts to the SD as a vcard.
well... someone's card anyway.
Got the phone back though (forgot it at the bar
) I exported my contacts to the sd card and put it onto the other one so Ill never be without numbers again.I have 3 sd cards...1 of which is always in my pc and it contains 2 cmw backups. Fortunately I do have a Google account so now getting my contacts should be no problem. The problem will be that without the phone, I can't tether, and tethering is my only form of internetGot the phone back though (forgot it at the bar
