1. When charging, the stratosphere will double up letters on the virtual keyboard. It also lags a lot when charging.
2. My data will stop working at random times. There will be no 3g, 4g or 1x. All I can do when this happens is call or text, but going on the internet or playing on apps is out of the question.
3. I noticed today that when I received a call, there was no ringtone, however the phone volume was on loud and I have ringtones set.
4. I plugged my phone in yesterday and the number that says how charged it is was going backwards. It went from 3% charged to 1%. I unplugged it and tried again and it worked
5. When using the pattern unlock screen, sometimes when I try to draw the pattern, it won't register that I'm trying to draw it. It will sometimes take 3-4 tries before it works.
These are frustrating and I just want to know if anybody else is having similar issues.
YES YES YES!!!! I've brought one Stratosphere back because of this and the second one is doing the same thing. My wife has the same phone and the same issues. Definitely does not transition well between 4G, 3G, 1X etc. For example, on my commute I have a 4G connection. When I get home and walk through the door, the phone switches to 3G and I lose my network connection. The phone still shows a 3G connection with bars, but there's no network connection. The other day I couldn't even text or make an outgoing call with it! I called customer service at Verizon and after about 20 mins, I was transferred to a senior tech who finally admitted that some of their 4G phones are having issues transitioning. I also noticed that the Wifi range sucks too. I switched to this phone from a crappy Blackberry Curve which could connect to my home Wifi from anywhere in the house and the yard. This thing can't pick up the signal from more than a room away.
