Help Anybody having trouble with weather bug?
Ally Cat
My search turned up dated information so, here goes. I am looking for a good dependable weather app that will work on my Ally. I used to love weather bug, but since the last update (either phone or app) it constantly forecloses and is basically useless. I have sent many bug reports to the developer and have not seen any updates, so I am looking for a different app that will work on this phone. I mainly am looking for an app with a good animated weather radar map, with a good widget for temp & current location conditions. Most of the apps on the Market seem to have lousy reviews not any better than Weather bug! Any suggestions are welcome! Thanks!
P.S. I have recently rooted and am now running velocity 1.1, still made no difference on the weather bug app still forecloses! What a bummer that app used to be so awesome, but tired of waiting for an update!
Weather Bug works fine for me. Try going to settings, applications, manage applications, then clear Weather Bugs data and uninstall and reinstall. Also you might want to move it to phone if its not though mine runs fine from the SD card.
Been out of town, thanks for the reply your suggestion worked like a charm!:D
Thanks again!
